AS500 vs C326BEE with C545BEE
My 'office' system (i.e. small room) is currently C545BEE -> C370 -> AVI Neutron V
The C370 is cutting out on one of the channels intermittently (I've checked all other components for fault by swappng them out - it's definitely the C370 at fault). I could get it fixed but that means lugging it over to Milton Keynes and doing without music in the office while it gets fixed. I don't really have time to go auditioning new amps (philistine, I know !).
I was just going to go ahead and order a C326BEE as a replacement when I read the reviews of the AS500 and was intrigued.
Would this amp work with the C545BEE ?
I listen to all kinds of music (not classical). I am more interested in detail than room rumbling bass, on paper it looks like the NAD CD player might work well with the Yamaha amp. Am I kidding myself ?
Blackdawn
88
I'm sure the Yamaha could be used to get a good sound but I would try the NAD first as the synergy should be better with the player. Also you are used to your old NAD so must like their house-sound. The NAD C370 is a good amp. Still worth getting it fixed and may sound better than the new ones you mention. You may find the replacements not so powerful sounding. Also it may take a while for the new amp to run in so initially the sound may not be the best. There is another post on here where a poster ran in the amp and speakers for a couple of days and the sound improved.
Excellent advice.
You're right, of course. Always wanting things sorted yesterday, that's my problem :)
I've promised myself that I wold build my own amp one day, maybe this is where I should start, with a simple project amp to replace the C370 while it's away being fixed :)
Not sure,
I've always found these guys very helpful www.technosound.co.uk
They resurrected one of my Ruark Crusader IIs from my main room system a while back and fixed my Audiolab 8000P, so they've already saved me quite a stack of cash :)
But their website no longer mentions a repair service. I'll give them a call in the new year
