- Aug 10, 2019
- 2,556
- 4
- 0
Hey, are speaker stands a standard size, because I have measured the indented square in the bottom of my KEF celeste IIIs and it is around 16cmx16cm (with a small hole in each corner) and i was wondering if this would fit perfectly on to a pair of Partington Super Dreadnoughts, which in the tech specs say are around that size. Would it be a coincidence if it fit perfectly, or is this a standard size for speakers and stands?
Thank you
Thank you
