- Sep 13, 2015
- 18
- 0
- 0
Hi my son is just a setting up a system on a budget. He's been offered a arcam alpha 9 amp for £120. The speakers he got are Wharfedale diamond 220. Do anyone know if this amp is any good. Thanks
Scroll down, when viewing the forum. You've had a few replies on your original thread.rockerman66 said:Hi my son is just a setting up a system on a budget. He's been offered a arcam alpha 9 amp for £120. The speakers he got are Wharfedale diamond 220. Do anyone know if this amp is any good. Thanks
The Arcam Alpha 9 in it's day was regarded as one of the best amps. If it is working well it's probably a reasonable buy but because of it's reputation it is not cheap for it's age. Try it out first. Crackles when changing volume is a common problem but usually nothing serious. Also switching between inputs can produce crackling. Spraying contact cleaner may cure this problem.rockerman66 said:Hi my son is just a setting up a system on a budget. He's been offered a arcam alpha 9 amp for £120. The speakers he got are Wharfedale diamond 220. Do anyone know if this amp is any good. Thanks
