ARCAM A75 Amp - Help Please.
Hi Guys
Feel a bit cheeky registering for help but needs must
I have an Arcam A75 integrated Amp which was working just fine. Now
when i turn the input selector *** i get no green light and am unable
to select my desired input Ie: CD, AV or Phono etc.
I only have an Arcam CD player connected to the Amp but simply cant
select it using the input selector ***. Therefore getting no output
from the CD player through my amp.
Any ideas or theories welcome
Pete
Plug the CD player into another input and try that. Is there any possibility you have the speakers switched off? Try listening with headphones. If not take it into an Arcam dealer and get it checked out. Its a good, simple design so it won't be much.
