Apple music problems
  • Thread starter Deleted member 116933
  • Start date
I was actually looking forward to apple music but as it stands through a computer if you want to listen to hi-res you have to manually change the sample rates manually. This is a bit of a bummer and renders it pretty useless if you want to listen to hi res.
Phones and tablets have no problem auto-switching and passing through what's there though but there is a number of negatives as well.
Shame as it has a lot of promise but i doubt we will get an Apple connect service any time soon.
Niallivm
137
64
4,670
I was actually looking forward to apple music but as it stands through a computer if you want to listen to hi-res you have to manually change the sample rates manually. This is a bit of a bummer and renders it pretty useless if you want to listen to hi res..
It’s one click and isn’t an arduous task. I have mine set to 24/96 regardless as I can’t hear any difference when adjusting it for 24/44 recordings
Reactions: RBinDC
Gonepostal
168
65
18,670
Am I missing something, all I've needed to do is change the settings on my iPhone se and connect it to the usb type A connection and it's good to go. Might be my mind but it sounds better than before. Brilliant stuff. I don't think I need to keep changing the settings, do it once and it's all good.
Niallivm
137
64
4,670
You’re not missing anything: OP was referring to changing the Audio Mini settings on a Mac
Reactions: RBinDC
RBinDC
59
22
545
Doesn’t AirPlay support CDQuality resolution? No dongle required.
I have the Buchardt A500 active speakers that connect wirelessly to a hub at 24/96 resolution. I doubt that I can hear the difference between 24/96 and anything higher res.
Reading this thread makes me think I should try directly wiring my iPhone 12 to the hub to stream the hi res Apple files. Has anyone tried this?
I jhave a 3 month free trial Apple Music subscription. I downloaded about 10 GB of music to my iPhone and was not charged. This sounds too good to be true.
If I cancel the subscription is there any way Apple can deactivate the files I downloaded free of charge? I have disconnected my iPhone from the internet and the files still play music.
For $10 per month I may just cancel my Qobuz subscription.
