BenLaw said:
Thanks for your thoughts JD. I suspect not being able to connect to a display is the sort of thing I'll never miss if I don't have it. Can I ask, how do you find finish and build quality compare to an iPad? How easy is to hold for a while in one hand? Do you find the screen ratio better or worse than that of an iPad in normal use? And do the swipe gestures work consistently well? Thanks for your help.
Right. It's obviously not as hewn-from-solid-block-of-aluminium as the (hewn-from-etc) iPad. It's a two piece construction, with a plastic back 'snapped' onto the bezel (I know this because when I dropped it on day two, the back separated from the front slightly, but it snapped back fine).
Don't be put off by the fact that it's plastic-backed - it's what car manufacturers might call 'soft-touch', and I actually find the feel of it rather better than the iPad, which is a bit cold and smooth and slippy in comparison. It's great for holding one handed, and the slightly elongated shape make it easy to swipe from left to right one-thumbed (reading the Times while strap-hanging, for example, which wasn't possible with the big iPad). OS swipe movements are perfect, but apps themselves can be variable - sometimes takes a couple of goes with the papers or kindle (though at least the latter has a one-touch page turn).
The screen glass is very nice, better than the couple of droid phones I've tried which have felt a bit scratchy.
I find aspect ratio fine. Sometimes it feels a bit tall, and one odd thing is that browsers tend, depending on site, to slightly stretch the site heightwise, so text looks a bit elongated on eg here and BBC (god bless 'er) at zero zoom. Firefox and Chrome don't consistently behave the same. This sorts itself out when you do zoom, however, and I suspect the dpi hack some have tried would fix it. (As an aside, I am finding Firefox a bit buggy). EDIT - also, it makes MUCH more sense now that they've enabled home screen autorotation - without it it was a portrait-aspect device, IMO, as it just behaved stupidly.
It's NOT an iPad. Primarily because right now, apps aren't as good (generalising). If you think of it, however, as a Kindle with knobs on (book reader, browser, occasional music and video usage - great from a screen def point of view but the free Transformers one I tried that came with it was a bit juddery), and compare it in price to one of those instead, then I think it's well worth the premium. If you've already paid for loads of apps on iPad or iPhone though, you might find replacing them on a different device - if they're even available - starts to take away the differential between it and the Mini.
