AntiCables - any good??
6th.replicant
294
Want to upgrade my speaker cable. Does anyone have any experience/knowledge of AntiCables' speaker 'cable' (aka coated copper wire)? CLICKETY It's just that it seems too-good-to-be-true in terms of price/performance? Any advice much appreciated. Ta [🙂]
I have them, i have written about them a few times on What Hifi, you may find my comments if you search google or alike.
I use their jumper cables after having read some good reviews a couple of years ago and they work a treat. If the speaker cables are as good as the jumpers then i'd go for them if I needed to.
Like 99% of cable suppliers they are an expensive rip off. Just buy 10AWG 12AWG cable from a supplier like bluejeanscable, its a great cable and a fraction of the cost at about £2.50/meter. There wiil be no audible difference between a rip off £10/meter 10AWG cable a £2.50/meter AWG cable.
heathpw:
Please do your research before you post, it is a cheap cable. I bought this cable directly from Paul Speltz from Anti Cable, unfinished from the roll it is only 1,25 $ per foot!
But there is a higher price to be paid (but not overly expensive) for a finished ready to use cable, here's why...
"There is savings when buying the Anti-Cable wire in bulk form. At $1.25/foot, you get it for essentially 1/2 price, (but it is not returnable).
For example, a 10 foot stereo set of Anti-Cables costs $100, or you can buy 40 feet (for $50) in bulk form to make a 10 foot stereo set. Be sure to buy 4 times the length needed (2 wires to each speaker, times 2 speakers). This is why a 10 foot stereo set requires 40 feet bulk wire to make.
I sell it for less in bulk form because it saves me these steps:
1) Drawing the wire perfectly straight (a 2 person job).
2) Measuring 4 wires to an equal length (a 2 person job).
3) Scraping off the red coating on the 8 ends (use a dull knife, a kitchen cutting board, and some patience).
4) The cost of 8 spades, RED & BLACK heat shrink tubing, and the time it takes to acquire these items. FYI: You can buy a set of 8 spades ($10), or 8 bananas ($20) and shrink tubing from me. Spades can be crimped. Bananas must be crimped, then soldered.
5) Crimping the spades on the wire ends.
FYI: bare wire ends are an option as well, and saves the trouble of adding spades or bananas
6) Heat shrinking the tubes over the crimping.
7) Forming the wires into perfectly round spools as a finished product.
If steps 1-6 seem do'able for you, you can save some money, and have fun at the same time.
Please let me know if you have any more questions.
I think you will really enjoy them!
Thanks!
Paul"
I'm amazed that someone with 2 posts will come along and suggest that 99% of cables are rip off rubish!. Is it me....
Seriously IS there an audible difference between £10-12 per meter wire to £2.00 per meter wire then ?
I upgraded (?) from copper wire (Gale, I think) wrapped in some kind of clear poly something or other coating from Richer's to silver anniversary wire around about two years ago ... when I hear the difference I'll let you know.
MartSmith:I'm amazed that someone with 2 posts will come along and suggest that 99% of cables are rip off rubish!. Is it me....
No, it's not you. According to heathpw's short posting history, just about everything is a rip-off...
Andrew Everard:
Now your putting words into my mouth, I said 99% of cables are a rip off not everything.
heathpw:Andrew Everard:
99% or 'about everything'....surely similar 'amongst friends'........
