I feel I have been ripped off with 4K HDR too!gel said:
gel said:I feel I have been ripped off with 4K HDR too!gel said:
It does if I want to though. That's why I decided against a newer games console.bigboss said:You don't play games, so this doesn't affect you.
The Panasonic was even worse on HDR 4K much darker, if I had known that HDR 4K was crap on LG TVs too I would've kept the Panasonic though.buzz_lightclick said:gel said:I feel I have been ripped off with 4K HDR too!gel said:
Do you still think the LG E6 is better than the Panasonic OLED you had before?
Nice one!andyjm said:Just replaced my ancient Panny plasma with an LG65B6 OLED. Took advantage of a John Lewis' black friday deal and got a 5 year guarantee thrown in and 1/3 off.
Worked for about an hour with a PS4 Pro on 4K then packed up. Retracing my steps, it was connecting the TV to the net and allowing it do a software update that killed it.
LG have identified a bug in the OLED 55 and 65 TVs that mean the HDCP2.0 handshake with the PS4 pro fails. There is a software fix available on their site that fixes this and other PS4 related problems. Unfortunately, the TV doesn't download this version automatically if you do an online update - you have to download the fix to a PC, unzip, copy to a USB stick and upload it to the TV.
To be fair, it has fixed the problem and the PS4 now seems happy with 4K and HDR - but its just like owning a PC not a TV (which I guess it is...).
One observation is that it is remarkable how thin the panel is without a backlight. For the 2/3 of the panel than doesn't have the 'gubbins' behind it, the panel is only about 5mm thick.
I am not sure to be honest. I think the US have brought out a firmware update but the UK is still waiting for one from what I can gather. You should try AV Forums too.SAP7 said:So,
has the software update reduced lag? As the link in the OP?
Or just just sorted the glitch?
I've bought a PS4 pro, considering sky q for uhd, and thinking of a new tv to top this off.
The alternative is holding off on sky go, and waiting another contract year on sky until I go hi def and bag a new telly
Confused.
