char_lotte
- Feb 27, 2012
- 9
- 0
- 0
Alec said:John Duncan said:Maybe they were too scared to say anything. Was the music Huey Lewis?
Fair dos, that was funny.
Agreed.
steve_1979 said:John Duncan said:Overdose said:Have you considered trying to find out at what point you could reliably tell the difference?
Me or him? If me, it starts to show itself about 256 and below. 128k is obvious to me on most stuff.
It's exactly the same for me too.
There is sometimes subtle difference at 256kbps. At 128kbps the difference is usually pretty obvious but music still sounds pleasant enough to listen to.
bigblue235 said:But she just likes to back up my assertions when I'm wasting money, she's just being sweet.
She's quite good at that 'pretending she's impressed' thing. Thankfully.
fr0g said:steve_1979 said:It's exactly the same for me too.
Rip to 190 VBR LAME. Then try the Foobar experiment. I bet you cannot pass the ABX test yourself.
At 320 MP3, AAC, OGG I don't believe anyone can tell the difference for real, but I stand to be corrected with a 20/20 Foobar test 🙂
steve_1979 said:Here are details of a 'lossless vs MP3' experiment that I have carried out on three different people. Each time results are the same. The experiment consists of three separate blind A/B listening tests and an ABX test.
1. For the first test I played a series of two identical MP3 files but lied and said that one of them was lossless. Most of the time they prefered the sound of the fake lossless file over the MP3 file even though it was really the same identical MP3 file.
2. For the second test I swapped the files around. I told them that the MP3 was lossless and that the lossless was an MP3. Most of the time they prefered the sound of the MP3 file over the lossless file.
3. For the third test I played the lossless and MP3 files again and told the truth about which one was which. Most of the time they prefered the sound of the lossless file over the MP3 file.
4. For the fourth test I let them do an ABX test using Foobar and nobody managed to tell the difference between the MP3 and lossless files.
proffski said:Importantly, what kind of 'music' did you use as your reference?
How and where was it recorded?
RobinKidderminster said:Am I missing something or does it matter about the source and the software conversion. I am not disputing nor supporting these results but I wonder if such tests have more variables than just speakers.
RobinKidderminster said:It is an interesting experiment which deserves consideration.
steve_1979 said:fr0g said:steve_1979 said:It's exactly the same for me too.
Ok I've done the tests and my findings mirror exactly what fr0g has said.
I cannot pass an ABX test comparing lossless to MP3's at either 256 or 192kbps. At 128kbps I can tell the difference but it is still sounds very good even at such a low bit rate.
I haven't done much experimenting with any bitrates other than 320kbps. I haven't actually tried doing any proper ABX tests using 256 or 190kbps MP3's so it's possible that the occasional subtle difference that I think I can hear at 256kbps is really just expectation bias clouding my judgement.
I'll try a few ABX tests in Foobar using LAME ripped VBR 190 and 256kbps MP3's. I'll report back later with the results.
steve_1979 said:Ok I've done some tests and my findings mirror exactly what fr0g has said.
I cannot pass an ABX test comparing lossless to MP3's at either 256 or 192kbps. At 128kbps I can tell the difference but it's still sounds very good even at such a low bit rate.
Overdose said:steve_1979 said:Ok I've done some tests and my findings mirror exactly what fr0g has said.
If when I get around to it I find the same, I'll be saving a fair amount of space. Is it likely that any further compression, down to 190 VBR would result in any additional problems, or would the result be the same as ripping from CD straight to 190 VBR would you think?
bigblue235 said:Steve, regarding your expectation bias thing, isn't it just the same as new cables, new CD players, new anything else? If you want there to be a difference, there's more likely to be one. It is interesting, but I don't think it's a new concept.
fr0g said:this is probably worth a re-post...
320 v 128... can you tell? (10 times in a row)
steve_1979 said:Expectation bias isn't a new concept, it's been known about for ages. My experiment is just another demonstration that shows how easy it is to fool people into thinking that they can hear differences that aren't really there.
This is why it's important to use blind rather than sighted testing whenever you're demoing hifi equiptment. If you can see what you're listening to you may be biased without even realising it.
bigblue235 said:So why are you just bringing up something that's well known about and suggesting we all need to think about it now? Is it just the basis for banging the blind testing drum?
bigblue235 said:I know I was joking earlier about the AVI forum thing
bigblue235 said:couldn't you maybe make a thread about something which isn't pushed over there, just for a change?
steve_1979 said:I undertook the experiment because I wanted to verify peoples claims about whether or not it's possible to hear a difference between MP3 and FLAC. The results of my experiment were interesting so I decided to share them with the other members of this forum (after all this is a hifi forum). Just because these results suggest that expectation bias played a big part in what people heard it doesn't mean that I'm banging any drums.
This thread has absolutely nothing to do with AVI. This thread is about MP3 vs FLAC comparisons and how expectation bias can effect what you hear.
Your comments don't come accross as joking either. If you're not interested in my threads why do you keep reading them and posting in them? You rarely have anything constructive to say either, you just make quips about AVI. I've always been polite and friendly to you yet you take every opportunity to verbally attack and be rude to me.
Like this one? http://www.whathifi.com/forum/hi-fi/x-mini-ii-portable-speaker-review
bigblue235 said:steve_1979 said:Expectation bias isn't a new concept, it's been known about for ages. My experiment is just another demonstration that shows how easy it is to fool people into thinking that they can hear differences that aren't really there.
So why are you just bringing up something that's well known about and suggesting we all need to think about it now? Is it just the basis for banging the blind testing drum? I think those that agree, will. Those that don't, won't.
I know I was joking earlier about the AVI forum thing, but couldn't you maybe make a thread about something which isn't pushed over there, just for a change? 🙂
