Amplifier for Wharfedale 10.1
I just bough the Wharfedale 10.1. What should be a good match fo the amplifier. It will be use for home cinema and music.
Thnak you for your suggestion.
Gilles
Thank you for your question,
I like warm sound not necesarely sound effect and helicopter vibration in the middle of the living room. Budget is 350 ? maxG
Arcam will fit the bill perfectly. My A65 is superb with films and tv in a standard 2-channel format. A second hand A65 can be picked up on ebay for around £150 - £180. Alternatively, Nad 352 is a wonderful option, and both these will be a good match for Wharfedales.
Or you could go with a brand new Marantz 6003 (£300), WHFI recommend this combo, but it really depends what source you have or intend on buying?
plastic penguin:
+1 for this, I have this amp with the Diamond 9.1 speakers for films and music and I love it.
