amp/receiver for Epos M12
TheHomeCinemaCentre:Welcome to the forum. I use an Exposure 2010 on mine and they sing with that. Of your two choices the Rotel would be the one for me.thankyou for the answer,what are the difference in sound's character between Marantz pm6003 VS Rotel Ra05?
I personally think that Marantz is a good match.
Rotels usually tend to send more detailed but less entertaining(musical) and provide little excitement.
This statement obviously doesn't apply to all Rotel products, but just some of what I've heard.
As everyone else would say, let yourself be the judge. What we perceive as 'good' differs from person to person. What kind of CD player, cables and amplifier you use it with can all make an impact on the overall sound, some components will excel at certain genres of music whereas some will perform consistantly good at all types but not really excelling in anything. My advice is to audition as much as you can untill you're satisfied with a certain sound that meets your budget and avoid making any compulsive purchases.
Creek all the way, either the destiny or evo amps will be the best.
Epos and Creek are the same company, one making speakers (obviously) and the other amps. They are made to be used together, then use solid core speaker cable as the internal wiring of epos speakers is DNM Reson cable. I used the DNM Stereo cable and it sounded great.
Hope this helps.
Thank you for the answer, i go to audition, exposure is very smooth,marantz pm6003 is bright and bombing bass,the midrange not detail, and i go to audition Rotel later..my cdp is Marantz 5001,Vdh d102mkIII IC,chord carnival silverplus speaker cables. The creek over for my budget..
well the creek evo mk1 from ebay would be a good buy and would fall around the same prices as your looking at for the other amps.
