Amp Problems
Hello,
I am new to this and not fully up to speed with the correct termonology.
I have installed a background music system in my restraunt.
It works for 15 mins or so then starts crackling. When I turn off thew CD player, these noises continue. It would seem the amp is at fault - its brand new.
Does anyone have any ideas? I am using 100v line with 4 speakers.
One idea I have is that I have the polarity wrong. I have kept it connsistent throughout. However, at the speakrs, the positive cable comes from the speaker and into a resister/coil. However, the positive now becomes black/ negative. Is this a mistake? Would it make any difference?
Sorry for the terrible working and lack of termonology. If I need to give any more information then please give me a shout.
Thanks a million.
Gordon
Hi Revit, welcome to the forum.
I am somewhat confused as to how you have your system connected up.
What is 100v line?
Why are cables going into a resistor / coil?
I suggest you disconnect all speakers and then connect just 2 directly into the back of the amplifier as per the instruction manual.
After you have done this do you still have the same problem?
Hi Gordon
Like alears I am puzzled about the "100v line" reference. However, polarity issues NEVER cause crackles - period!
What gear are you using, and does the supplier offer any help?
Any particular reason you chose a 100v line system when your only running 4 speakers?
100v line systems are usually installed in places like shopping malls to connect lots of speakers together over very large distances to one speaker cable.
I suppose any one of the output transformers could be responsible for noise in the line system.
check all your connections are good and maybe try a elimination process.
Start by trying the system with just the first speaker connected and see if the crackling persists, and then work through to speaker 2, 3 and 4.
If the crackling is still there using only 1 speaker it could be the 1st transformer or the amp.
Hope this is of some help to you.
