Amp for Dali Oberon 7 speakers
drumajo
I am not sure that I can answer that, can you audition anything?
The Dalis are not exactly a difficult speaker to drive so I would say anything that outputs 50-100 wpc should be plenty adequate.
It would obviously be helpful if we had some idea of budget.
Thank you for the reply.
I'd say up to £1,500 re the budget
drumajo
you say networked, will you be using other sources at any point?
Yes, Bluetooth, optical (x2), a decent app required. Be able to read from a NAS, FM/DAB radio, ability to hook up to a MacBook Pro, a good DAC, a sub input, Apple Play a must! A HDMI Arc would be nice but not essential
