- Aug 10, 2019
- 2,556
- 3
- 0
Hello all,
Due to budget constraints, I'll be building my new system in phases. The first phase will be speakers, the second being an amp.
My current setup is:
Pioneer VSX-820 amp used as a home theater amp (tv connected, tivo, dvd, etc all via HDMI)
I just bought ATC SCM-11 speakers that will arrive in a few weeks. I would like to replace or bypass my current amp for music to the ATC speakers. I'm fine leaving the Pioneer as the center for the home theater, but not for music.
My options as I see them are to completely replace the Pioneer for use with music AND my current home theater or simply get a new 2-channel amp and use that only with music to the ATC's and keep the Pioneer.
My 2 questions are:
1) Which setup would you guys recommend between getting a new home theater type amp and using that for music and home theater vs having a seperate home theater amp and music amp.
2) If the recommendation is to get a new amp just for music, which amps should I be looking at? The ATC's seem to be pretty power hungry (max 300 wpc) so I would like something at least 150 wpc.
Thanks for any and all help!
...Josh
My 2 questions are:
...Josh
