- Aug 28, 2014
- 1
- 0
- 0
Hi, So I have an Ekho SX-650 amp (http://www.whybuynew.co.uk/pa-systems-live-sound/ekho-sound-sx-650-1300w-amplifier.htm) which broke last night. Connected to the amp were two Skytec speakers (http://www.hifi-tower.co.uk/Pair-Skytec-DJ-PA-Blue-Dual-10-Passive-Speakers-1600W_i4315.htm), and two Sony hifi bookshelf speakers. Sony's were connected to outputs on the rear of the Skytec's, so I think they connect in parallel. I have used this setup for some time without problem, and at much higher volumes for longer periods than when it blew. Possible causes of problem:1. Amp was cold and put on reasonable volume almost immediately (around 1/2 of maximum).2. On one set of the Sony's the wire that connected it to the Skytec is infact two wires spliced together. I moved something and I think the positive/negative wires (at the splice point) may have come into contact. Any suggestions as to how to fix this/what component(s) may have been blown? There was a faint smokey smell after it blew, however no components look burnt at all. Many thanks, Andy
