All in one 5.1 blu-ray system with inputs
matengawhat
697
15
18,895
A work colleague of mine is after an all in one 5.1 blu-ray system like the Sony e370 but i was wondering if anyone knows of any that have additional component/hdmi inputs that the unit can then convert and send out over hdmi? Or will he have to take the seperates route?
Basically want to connect a sky + box to be later updated to sky HD and a Wii console so at least 1 component and 1 hdmi input that the machine can then output over just 1 hdmi cable to a projector!
thanks
Where you're going to struggle there is the component input - if you really want to connect the Wii video channel to the system, the best bet is definitely a separate AV receiver. If you're willing to connect the Wii directly to the projector via component, then have a look here.
