spiny norman
- Jan 14, 2009
- 293
- 2
- 0
David@FrankHarvey said:I prefer port if it's all the same to you....
With or without foam bungs up the back passage? ;-)
Foam "rings" 🙂spiny norman said:With or without foam bungs up the back passage? ;-)
Especially when it's moist 🙂spiny norman said:Does it? Even when you dampen it?
Vladimir said:David@FrankHarvey said:Has to be ultra controlled conditions though, and product swaps within 3-4 seconds due to not being able to remember anything 5 seconds ago, otherwise it won't count 🙂bigfish786 said:i honestly believe if you go out into the real world and listen/demo products, you will hear the differences, and make your own mind up whether any product is worth spending your cash on.
Ridiculing the science that creates the products you sell and buy is literally sawing the tree branch you sit on. *nea*
radiorog said:Vladimir said:David@FrankHarvey said:Has to be ultra controlled conditions though, and product swaps within 3-4 seconds due to not being able to remember anything 5 seconds ago, otherwise it won't count 🙂bigfish786 said:i honestly believe if you go out into the real world and listen/demo products, you will hear the differences, and make your own mind up whether any product is worth spending your cash on.
I'm lost oh these comments. Was David being sarcastic? I'm wandering why you are disagreeing here Vlad, I thought you agreed that auditory memory was about 5 seconds?
very good idea..start a thread..of course everyone will start banging on about the field being uneven..different amps, speakers, source etc..who cares! It would be interesting to see what others kit brings to the same track?SemiChronic said:This might be a rubbish idea, but ill throw it out there anyway. Thinking about how much gear there must be belonging to members, different amps speakers etc.
Would it be interesting and maybe helpful to members if we were to identify some tracks with tricky music that trips up some systems and report our findings?
We may find that certain amp/speaker combos perform better with certain tracks or show no difference whatsover . . it could be fun and we may learn something.
I would start a thread, but it would be sure to go down in flames if i did, so if somebody else would care to take it on, be my guest.
Id like comparisons from members with same amps/speakers playing same tracks but running different cables . . 🙂
Ok, nuff said . . . I'll reach for the fire extinguisher . .
Thompsonuxb said:Amps are not equal.
To anyone saying they are and who say they all sound the same, frankly you need to ask yourself what are you doing here on this or any other hifi forum?
To those talking about 'level matching' or 'controlled conditions' I say stop being silly. To those talking about the science I say aaaahhshaaddap!
I listened to 3amps on Friday with distinct differences within the same price range-ish. The threads still on the front page.
For argument sake if say I had requested they be level matched 2 of these amps would have to be seriously compromised to accommodate the 3rd.
To the OP if you really want to know if amps are 'equal' go and listen to a few at your local hifi dealer and decide. It's the only way.
+1Thompsonuxb said:Amps are not equal.
Yes, I was, for the most part, being a little sarcastic last night. I was doing it to show we can all be sarcastic when we want to be, and if we all did, this wouldn't be a very nice place to spend our free time. Healthy, polite discussion is all that is needed round here for it to flourish, rather than travel the well worn route 'down the pan' like some other forums.radiorog said:I'm lost oh these comments. Was David being sarcastic? I'm wandering why you are disagreeing here Vlad, I thought you agreed that auditory memory was about 5 seconds?
But then if they're playing anything over a few watts, the opposition chimes in with the amp clipping excuse, and that is the difference you're hearing. There is no way to win.ID. said:Really? Was the third amp rated at a fraction of a watt or a few milliwats? Considering the fact that most amps only operate withing their first few watts most of the time and that it takes a hell of a lot more watts to achieve significantly more volume...
ID. said:Thompsonuxb said:Amps are not equal.
Really? Was the third amp rated at a fraction of a watt or a few milliwats? Considering the fact that most amps only operate withing their first few watts most of the time and that it takes a hell of a lot more watts to achieve significantly more volume, it's probably pretty easy to level match amps that are withing a few dozen watts of one another while still having them playing at a decent volume? Or do you only test amps by seeing how loudly they can play? I always get this funny image of Thompson setting up what he thinks volume matching is. You seem to think it's a matter of turning the volume down so low that everything is barely audible, while in fact it's just having the amps operating within a comfortable range and adjusting the volume a decibel or two. They are still required to play plenty loud enough to enjoy the music.
In terms of a blind test, the speakers you tested have a pretty tricky impedence curve which might throw a number of amps off and separate the men from the boys (the sheep from the goats?), perhaps even to the extent that it could be picked up in a blind test. But once again, the issue isn't about volume, but having a power supply that can provide enough current to handle the bass on the B&Ws.
David@FrankHarvey said:But then if they're playing anything over a few watts, the opposition chimes in with the amp clipping excuse, and that is the difference you're hearing. There is no way to win.ID. said:Really? Was the third amp rated at a fraction of a watt or a few milliwats? Considering the fact that most amps only operate withing their first few watts most of the time and that it takes a hell of a lot more watts to achieve significantly more volume...
I understand the need for blind tests, but you don't need them to find out if you enjoy listening to a product/system.
drummerman said:TrevC will be along shortly underlining all amplifiers sound the same, all cables are the same, all cd players/Dac's sound the same ... did I forget anything?
The usual caveat is ... 'all else being equal' ... and therein lies the issue. Rarely is all else equal.
nopiano said:That's a good point, Chebby, and that other journal does still provide a helpful mix of technical tests with their listening results. There often is a correlation, and sometimes an outcome 'despite' a certain measurement.
I've tended to most enjoy products that seem to measure well and have a good engineering basis, and sound fine too. I've always been nervous of weak measurements that apparently sound good, which may explain why I've always shied away from valve amps. I'd love to try one though!
Thompsonuxb said:ID. said:Thompsonuxb said:Amps are not equal.
You'd have to hear them for yourself but in a nutshell your argument is silly.
keeper of the quays said:Amplifiers aren't equal..if the people on here believe this twaddle..why haven't they got the cheapest amp in their kit?
