camcroft said:I am looking at both of these headphones could anyone please point me in the right direction.Thanks
camcroft said:Hi.I auditioned the AKG`s this weekend and found exactly the same light in the bass dept I also listened to the Sennhieser Momentums which I found very good and also listened to the new NAD`s which were expensive but the sound and build quality were both excellent.Any thoughts.Thanks again![]()
The K550 and DT770 seem to hover around £140. You'd be hard pressed to get either the HD600 or HD650 for that money so I'd be curious if you have any lilnks for that? IMO both of these Sennheisers are far superior to either the DT770 or K550 so this seems fair. The HD600 seems the most balanced tonally speaking, whereas the HD650 is a little warmer, more boomy, but still quite flat and both amp really well. Compared to the other two the Sennheisers have much less annoying / inconsistant treble, while still being very enjoyable. There is good reason why these headphones hold their value, so if you find some for under £200 it's an absolute bargain!bay24 said:If you don't mind sound leakage (in and out) I would also try out the sennheiser hd 600 or 650, both could be got second hand for around your budget.
quadpatch said:The K550 and DT770 seem to hover around £140. You'd be hard pressed to get either the HD600 or HD650 for that money so I'd be curious if you have any lilnks for that? IMO both of these Sennheisers are far superior to either the DT770 or K550 so this seems fair. The HD600 seems the most balanced tonally speaking, whereas the HD650 is a little warmer, more boomy, but still quite flat and both amp really well. Compared to the other two the Sennheisers have much less annoying / inconsistant treble, while still being very enjoyable. There is good reason why these headphones hold their value, so if you find some for under £200 it's an absolute bargain!bay24 said:If you don't mind sound leakage (in and out) I would also try out the sennheiser hd 600 or 650, both could be got second hand for around your budget.
