after using rbh speakers
markyboy156
203
hi all
i am after using two rbh r55ti towers as fronts and r56ci centre speaker and two more r55ti towers as rears
and either e55wi as extra rears e5bi as extra rears in peoples oions what would be best out of the two
i will use 4 tm-815 in ceiling speakers for atmos
these will be connected to a denon 6200 and xpa3 amp the front three connected to the emotiva the rest to the denon using blue jeans interconnects and oppo 205 and using two pc 2000 svs subs and i want to use two additional subs using audio quest y splitter cables
in peoples opions what would be the very best 2 other subs to use thanks
Technically, you can pair a PB13 Ultra with PB2000 with each Y splitter and see if it works.
That $400 offer on Amazon.com is most likely fake or the subwoofer doesn't work. That seller has only 3 ratings and has asked to text him before placing order to confirm product condition, which should already ring alarm bells. I would avoid that seller.
Benedict_Arnold
661
Why do you keep asking questions about AMERICAN speakers on an essentially BRITISH forum?
Suggest you go to one of the American ones like avsforum-dot-com and ask there.
