I recently bought a pair of Monitor Audio Bronze 2 front speakers and a Bronze centre speaker which i am using connected to a new Denon 2300 AV reciever.
I now wish to add a sub woofer and two rear surround speakers into my 12' x 12' room. The two rear speakers will have to be fitted high up on the wall (one approx. 7 feet to the underside of the speaker to be fixed above a door and can only be about 18" from the side wall). I have been told that I should if possible keep all the speakers the same make and range as they will then all tonally match.
I have been told the Monitor audio bronze FX speakers would not be suitable for this application as they have to be about 6' above the floor and a few feet from a side wall. I was thinking of using a pair of monitor audio MR1's as rear speakers tilted slightly into the room near each corner these are front firing only and are rear ported. How would these work being tight to the rear wall?
I was thinking of getting the Monitor audio MRW10 sub woofer which i can get for about £239 which is above the price I had orginally planned on spending but that is the cheapest of the MA range.
Also is it worth spending a lot on a sub woofer cable - I have seen a Fisual Pro Install cable from amazon at £5.50 recommended in the forums and wondered whether spending £20 on a Cambridge Audio would be worth it.
Any advice would be much appreciated - this is my first attempt at a 5.1 home cinema setup.
