I've just bought a second hand SACD player on eBay. It works fine and sounds great, but it was covered in a thin layer of dust when it arrived, not only on the outside but over the CD loading tray as well. So I suspect there might be some dust inside the unit. What would you advise to do? Should I clean it with a CD lens disc? I am not sure if these, even the branded ones, are safe? Or open the unit and clean it with a little distilled water? Or just leave it... Generally, I am not sure if dust can affect the lens on CD players? I have never bothered with my other CD player as I always make sure my CDs are clean before playing them. Thank you for your help.
