- Aug 10, 2019
- 2,556
- 5
- 0
Hello all,
Excuse my ignorance on matters home entertainment, which will no doubt be evident with this post.
I currently have a basic music set up at home, that I'm looking to replace - an old hi fi mini system and speakers. I have a pretty new Philips HD TV and Dell laptop that I'm hoping I can hook in a home cinema solution into. DVD player is a few years old, happy to replace that if needed. I'm looking for a solution that will -
- allows me to run music and TV through surround sound speakers (or something that gives similar sound quality) - ideally into multiple rooms if easy to do
- allows me to use the laptop as the home for music, probably via wireless link up, also allows CDs to be played
- I also have an iphone and iPod classic - any solution that integrates well with these is good
- I'm not a massive audiophile, so not looking for something hugely top end, just something that sounds good and is a good value answer
- I am a bit of a sucker for a gadget though, so could throw a bit of money at it if there was something particularly cool out there
Any advice, pointers to previous posts, thoughts on what I've suggested above or suggestions for a good shop to speak to (Richer Sounds?) would be much appreciated.
Cheers,
Ben
Cheers,
Ben
