- Aug 10, 2019
- 2,556
- 5
- 0
Does anyone know anything about the Adcom GFA-5400 Amp? Specs: Detailed Specifications: Number of channels 2 Watts per channel into 8 ohms 125 Watts per channel into 4 ohms 200 Bridged power @ 8 ohms n/a Rated THD 0.018% THD + noise at full power into 8ohms/4ohms typical 20Hz 0.018% / 0.018% 1kHz 0.020% / 0.020% 20kHz 0.140% / 0.165% Input required for 1 watt output 0.1 volt Input required for rated output 1.125 volts Dynamic headroom into 4 ohms 1.7dB IM distortion CCIF full power any combination 4kHz to 20kHz 100dB Power consumption (all channels driven) Quiescent 150VA Maximum 960VA Dimensions (inches) HxWxD Chassis 5 x 17 x 11-1/2 Maximum 5-1/2 x 17 x 12-1/2 Weight (lbs) Net 26
