ADC question
There are loads of audio interfaces that will support those sampling rates. Do you specifically need a phono stage though? I think that is quite a rare feature. It can be added through a seperate pre-amp if necessary.
Something like the Steinberg UR12 or Behringer UMC202HD are at the cheaper end of the range.
Gray
Thanks for your reply Jon
I don't actually need the phono preamp section, but that ADL was the only 24/192 ADC that I'd so far seen (at that price or lower).
Strangely, I've bought Behringer (effect unit) myself and recommended the UCA202 to another poster - but so far had never noticed what you've pointed out.
So thanks very much for bothering.
