Acceptable level of hiss?
I've had my Sony STR-DH800 for a couple of weeks now, and am increasingly aware of hiss at high volumes. I realise that you will never get rid of it, but what is an acceptable level?
With the amp set to 'Analog Direct' there is no hiss. But when I switch to the optical connection to my SkyHD box, pause Sky and wind up the volume, the hiss is noticeable at around a volume of '30' which is the level I would use for watching a film.
I'm assuming therefore that the hiss is due to the sound processing. Have I got a dodgy unit, or is this just normal?
Many thanks
Mat
That doesn't sound right to me - I don't see why it should hiss, just 'cos it's got the optical connection.....
applehead1970:But when I switch to the optical connection to my SkyHD box, pause Sky and wind up the volume, the hiss is noticeable at around a volume of '30' which is the level I would use for watching a film.
Or of course possibly the Sky box...
Thanks for your responses. I get the same hiss on other inputs, so I don't think its the Sky box.
Do you think using banana plugs or bi-wiring would help?
Depends if it is in fact a hiss.........if you put your ear up to the rear speakers and you get a squelching sound, this could just be the inserted pieces of data that you get with artificial 5.1 when the original is in stereo. The fact that it goes away in pure mode does strongly point towards this
And again it could be interference from another piece of equipment located nearby. Only way to find out is disconnect and turn off everything except the speakers, then listen again.
