WishTree
Option1
enon Cara S-5BD
Blu Ray Player with AV Receiver - Drives Center Speaker and sub woofer, pre-out go into the HiFi Integrated amp for Front Left and Right. Volume controlled by Cara
Option 2: Oppo BDP -105
Blu Ray player with Pre-amp - Drives Center and Sub woofer (You need atleast one channel power amp for Center) and the volume is controlled by Oppo. Also Oppo DAC is pretty good and can act a a proper CD player. If there is an active version of your center speaker available then no need for a seperate power amp to drive the center.
Option 3: Seperate Blu Ray Player & AV Receiver
Any of your choice & Budget. AVR drives the center and Sub and volume is controlled by AVR
However in all the cases, ideally Center Speaker should have similar tonal balance as the FL, FR (Same brand, same series). The Power amp or AVR's Power section makes not much of a difference (There might be slight noticeable effect but not worth focussing on this area, IMO)
Option 4:
Seperate HT and HiFi. Easy to handle but might miss out the SQ levels of the HiFi
Cheers!
Option 4:
Cheers!
