Goodmorning to all
I would like to ask for some advice / opinion from you, especially if you own the KEF LS50.
I have them paired with a Rega Elicit (Mk2). Prior to that I had an Arcam A29 driving them. The Elicit is a major improvement (especially in the bass and rhythm) but a problem persists and it has to do with vocal clarity. In short, while the midrange is great, I get the feeling of a recessed top. Music sounds great most of the time but I do get this feeling some of the top end is a bit more laid back compared to what comes before in the frequency spectrum
This issue is however evident when i watch movies (Apple TV4 > TV > optical to Rega Dac-r > Rega Elicit). The vocals / voices / speech sound a tad recessed and they are not easy to understand, especially if other things are happening in the scene. I wonder if this is indeed the sound signature of the LS50?
I did some research and found that the frequency response of the LS50 shows a slightly prominent 2-5KHz followed by a dip in the 6-10 Khz range.
This varies in magnitude but it is shown in a number of reviews.
http://www.kef.com/uploads/files/en/review/LS50_HFN_0712.pdf
http://www.stereophile.com/content/kef-ls50-anniversary-model-loudspeaker-measurements
Prior to the LS50 I had the B&W CM1 S2 which had the opposite issue (prominent '...ssss' and sibilance at the top while midrange was recessed). My room is underdamped and bright so I have always had issues with treble (especially for example with Monitor Audio speakers I had a while back).
Am I doint something wrong with positioning or perhaps something else? Maybe the above is indeed the sonic signature of the LS50?
I can try using EQ with movies if I swap the Apple TV with a PC but I would love to first ascertain if indeed this is needed.
Many thanks in advance
PS: I have had the LS50 for a few months (totally broken in) positioned on solid stands and about 11inches from the back wall, slightly toed in. Cables are Chord Odyssey II.
