- Aug 10, 2019
- 2,556
- 5
- 0
I've got my 9.1 ATC system all together now: ATC SCM19 fronts, C3C centre, SCM11 sides, SCM11, rears, SCM7 front heights & C1 Sub.
I'm looking into a few different options for amplification, but, where I'm quite stuck, is with the Processor. The Onkyo PR-SC5507 looks like it could be a great fit for me but I'm not sure. At one place it sells for AU$3580. The Onkyo TX-NR5007 is going for AU$3750 at the same place--is this maybe an option: it's basically Power Amps for an extra AU$170 vs XLRs (I don't believe there are any other differences), yeah? (Even though I don't need the power amps that are in the TX-NR, they could be handy at some point, particularly if one of the amps/channels in my power amplification that I'll get go bust.)
Are there any other alternatives to the PR-SC55007/TX-NR5007 (other than the comparable Integras)? I'm also open to Receiver suggestions if they aren't too much more expensive.
Note: I am in Australia so prices are wacky here; or are they wacky in the UK and normal here...
