Beta4Me:MUSICRAFT:
Hi Beta4Me
As i have mentioned to you before the Yamaha DSP-Z11 will be just fine with the ATC's. I have used the DSP-Z11 with the ATC's almost constantly for a year and it performs superbly with them.
If you want to significantly improve upon the DSP-Z11 than the only components that do this are the truly magnificent Chord Electronics DSP8000/8000R and SPM 2400/SPM 3005 processor/power amp combinations. However they are between £15k - £30k.
Imho choose the DSP-Z11. For me Yamaha inspires confidence.
I know you've mentioned it before, but I wanted some more opinions and rathered have a new thread than revive an old one (and one that wasn't overly active--this is getting more posts more quickly
And, OK, it does seem that the Yamaha Z11 is quite good. Are price-comparable options such as the Denon AVC-A1HDA and the Pioneer Susano performace-comparable with the Z11? (The Pioneer looks so sexy...and the touchscreen...*drools*; but audio performace is more important to me than looks, especially when it's all going to be hidden away in an equipment rack.
MUSICRAFT:
Btw, the SCM19's are significantly better than the SCM11's. It is with the SCM19's and above that ATC really start to flex their muscles having already given an exceedingly good taste of what they are capable of with the SCM7's and SCM11's. The SCM19's feature a massively engineered mid/bass unit that uses ATC's Super Linear Magnet Technology to help reduce distortion even further compared to the already impressive SCM11 with the CLD mid/bass unit. The SLMT mid/bass drive unit itself weighs more than a complete SCM11.
FrankHarveyHiFi:
With the slightly larger cabinet volume and larger mid/bass driver, the 19 has a more authoritive sound, and little fuller too - a little like the difference between the 7 and the 11. Another difference you'll notice is when sounds are moving from speaker to speaker, whether this is voices, vehicles, or even ambience, you'll notice that in most systems the sound will change. This is because rear speakers are usually a smaller cabinet volume, use smaller mid/bass drivers, and because of this they have a different 'voicing'.
You could start with 5.1 with the 19's then add another pair at a later date when funds allow.
Thanks for the info on the SCM19 vs SCM11. I can see how the SL driver will make quite a difference (and the extra weight of the 19, WHOA!). With the cabinet volume, I was under the impression that all of the ATC speakers sound the same, just with more bass weight and overall power as you go up the product line; is that not true? I.e. will the SCM11 and 19 sound different (the 'voicing') due to the difference in cabinet volume?
Hi Beta4Me
I would still suggest the DSP-Z11 over the AVC-A1HDA and SC-LX90.
All the ATC Entry Series speakers have the same tonal balance so that mixing models does not cause problems.
All the best
Rick @ Musicraft
