6ohms or 8ohms
Jamestechnics
Hi All.
I am new here and wonder if any one has any advice on my speakers to buy. I have a Technics SU-V4 amp running a Pioneer PL-514 turntable but need speakers.
The Speaker load impeadance on the amp is 4 ohms to 16 ohms I take it this means that I can use 4, 6, or 8 ohms speakers?
Thanks in advance, Jim.
spiny norman
293
Yup, and remember that the impedance figure quoted for speakers is only nominal: the actual impedance varies along with frequency on all speakers, to a lesser or greater degree.
Infiniteloop
51
6
Jamestechnics said:
Hi All.
I'd just listen to loads of different speakers until you find the ones you like the sound of best, for your budget. Your Amp should be fine driving any of them.
