Andrewjvt said:
				Blacksabbath25 said:
			Hi Andrew
yep that's how I used to do it years ago when AVs never had the YPAO I find the old way easier
ive been reading on the Av forum about setting the L+Rs to small or big they say ones I get a sub then this setting will be available to me in the Av menu and then I can set my crossovers as well .
but sounds great with just 3 speakers connected and my Dali opticon 8s knock some bass out when watching a films  .
but thanks for the help *smile*
Once all connected with surrounds and sub let us know how it sounds
 yes will do
I've changed my mind on the back speakers as I was going to buy 2 more Dali opticon LCRs but thought about it and cancelled the order as I thought spending £500 each for back speakers was silly .
so ordered in the Dali opticon 1s to look at as I do not my living room looking like richer sounds show room so the opticon 1s will sit quiet happy next to a wall and I will use my speaker brackets to support them  .
the opticon 1s are £499 for a pair and to be honest I did not really want to spend that on backs I was thinking on the lines of zensers 1s or the peco 1s of the Dali range as you do not get that much sound out of the backs anyway but I phoned the richer sounds shop up to day to cancel my order on the LCRs and spoke about why I changed my mind and they thought it was over kill spending £499 each on 2 backs .
so they thought it would still be better to keep with the opticon range but go for the opticon 1s and then I was hoping at the same time buying the sub and speaker cable for the backs and a sub cable .
But it's been so long since I've had a home cinema setup I forgot if it's worth spending good money on back speakers or not I've definitely spent the money on the font end which the shop thought was important to get a good sound out of it all  .
i would normally post this in the home cinema threads buy hardly anyone respondeds to your posts only big boss so sorry Admins .
