Hi Nugget2014
As promised please see below for some useful links to resources which can be used to help calculate multiple subwoofer positions, speaker positions, room modes etc etc. Properly applied this information should assist you on your quest for audio and video nirvana.
Room mode calculator (basic) -
http://www.harman.com/download/file/fid/2156
Room resonance (advanced) -
http://www.harman.com/download/file/fid/2141
Multi sub positioning
Part 1 -
http://www.harman.com/sites/default/files/white-paper/12/11/2015%20-%200...
Part 2 -
Part 3 -
If you get serious and want to sort out your room acoustics, here is a nice analitics app from the fellows at Artnovion.
http://www.artnovion.com/impulso-app (needs to be used with an iPad ideally) - you use this app and the resulting file combined with a scale drawing of your room, fixtures, fittings and funiture positions and type to send to artnovion who, for a small fee, will run full diagnostics of your room and recommend suitable absorbsion, diffusion and reflection panels.
Finally.
Here is the link to the Dolby white paper I mentioned on speaker placement for Atmos.
http://www.dolby.com/us/en/technologies/dolby-atmos/dolby-atmos-home-the...
Please note the rears are depicted behind the listener (slightly) although can be as far forward as level with the listener. please also note the speakers are all on the same plane (i.e. not elevated).
In you room I would be a little concerned that the rear right speaker would be placed too high (over the window) and the separation for the height channels in Dolbly Atmos would be missed. This combined with the fact the rear left is at ear level could produce some very weird effects. It may be more worthwhile investing in some speaker stands for your side speakers so they are at least at the same height and so they can be repositioned for best effect depending on how they interact with the environment. This should (long term) assit with Dolby Atmos overhead speakers becoming more effective.
A separate guide for traditonal 5.1, 7.1 and 9.1 can be found here
http://www.dolby.com/us/en/guide/surround-sound-speaker-setup/5-1-setup....
http://www.dolby.com/us/en/guide/surround-sound-speaker-setup/7-1-setup....
http://www.dolby.com/us/en/guide/surround-sound-speaker-setup/9-1-setup....
With respect to your viewing distance I found this tool to be very useful in the past.... Note that it shows pixels per degree not pixel per inch. It also references the documentation to back up its calculations. Of course other rules will apply regarding seating distance from screen and field of view, but I find this is a great starting point to make sure you are getting the benefit of any given resolution screen at any given distance.
http://phrogz.net/tmp/ScreenDens2In.html
Good luck with your project.
PS
Here is the room correction I mentioned - needs to used in conjunction with REW.
https://www.minidsp.com/
50 min long video from AudioHolics explaining how it works here
https://www.youtube.com/watch?v=Mq05vAAnryY
Enjoy
