3D connection issues
nads
886
238
19,270
yep I can see your problem. you need some cables.
So what are you connecting together?
and what are you using to connect them?
and finally what problem(s) are you having?
PS welcome.
micks_address
159
are you looking to get 3d from sky hd? best bet is HDMI direct from sky hd box to the 1.4hmdi slot on your tv - check the manual for which one.. maybe all of them are 1.4.. then run optical cable frmo sky box to 1910 for 5.1 from sky
