20 meter long budget speaker cable recommendation
Jan 14, 2016
I am quite ignorant about speaker cables so I would apreciate your advise.
I need to connect my Onkyo TX8050 receiver to a pair of Mission MX1 speakers (this will be a secondary set of speaker connected to the Onkyo) that will be placed between 15 and 20 meters away from the Onkyo receiver.
I therefore need a couple of 20 meter long cables. I am not willing to spend tons of money on cables (I would prefer not to spend more than 50 pounds).
Would you reccommend me any particular cables for this job? Is there a minimum wire gauge or thickness that I should get?
Thanks!
Martin
It is 79 strand which is good. Thickness and guage are mentioned in the link. I cannot remember if it's OFC, I think it is. Check it out at your local Maplin.
An alternative is Van Damme which are good value for money.
