Hi!
I currently have the following setup - squeezebox duet > beresford dac > Denon 2808 > tannoy mercury f1 custom's with wharfedale sw250 (bit of a monster sub). I use this setup for music and movies in the living room, although of course the dac isnt used for movies.
But i managed to pick up a pair of mission m33 floor standers from ebay for £50 - i will be using these connected to my computer in the bedroom. However i feel like i should really use the dac for this system as without using the dac i have to connect pc > amp > speakers with a 3.5mm to phono cable which sounds awful. So i have the following choice, which one do you recommend.
1. squeezebox duet > Denon 2808 > tannoy mercury f1 custom's with digital coax (qed) or
2. squeezebox duet > Denon 2808 > tannoy mercury f1 custom's with phono cable
which will sound best?
this leaves my second system as:
pc > beresford dac (via optical) > arcam alpha 8 (via phono cable) > mission m33
Or do you think removing dac from main system will really degrade the sound? i listen to most music in living room. Thanks for your advise!
Simon
Simon
