RickyDeg said:
Gosh... I can only imagine the level of compromise involved squeezing 11 channels of amplification inside of a one-box solution. Yikes!
Onkyo TX-NR3030, but it does weigh 22kg and costs £2,500, for instance at Peter Tyson.
RickyDeg said:
Also, the question is - can one even run Audyssey on a full 11.1-channel set-up? I was under the impression the current Audyssey have limits there.
Yes, as bigboss says, I run Audyssey on 11.1 channels, since the year 2010 in fact. The only comment that I would make is that I find that Audyssey is quite accurate at measuring speaker distances and sizes, but on speaker levels (how much to send to each speaker) it's not accurate, in my room at least, for the centre channel and the subwoofer, though it is accurate for all the other ten speakers. I find that I have to
increase the centre channel by about 5dB, and
reduce the subwoofer channel by about 3dB, from the levels that the Audyssey calibration suggests.
