Prce in demark is the same
Dali spektor has a darker sound than zensor, zensor sound more clear,open and dynamic
Spektor is the new entry level speaker from dali
For that size room Zensor 3 would be fine as long as you can give them some room to breathe and don't sit right against a wall. To make them within your budget you'd need to go second hand or ex demo. They would be ok with your Denon as well. I've had mine with Onkyo A9010 and the match was really good.
Zensor 1 lacks a little in low mids so will not suit all types of music. Guitar based music particularly suffers on Zensor 1.
Perhaps demo both if you can and if you prefer a Zensor 3 either get and ex demo pair or get them second hand. This way you'd at least be buying after some auditions.
Dali Spektor is dalis entry level speakers and they would be used with cheap amps and im pretty shure they would be easy to handle for budget amps since they are not made for high end amps
bubobubo said:
yes i found a concept 1 for 50 euro like new condition works perfect and i dont know it had all the bass i need, so i dont know what bass maniacs tells that this speaker dont have bass, most important is so acurated my friend nothing less or more like a real neutral one *give_rose*
regards
They don't have any bass and sound bright, terrrible speaker
Q acoustics 2010i much better
