I have been contemplating a speaker upgrade for some time but would appreciate any thoughts and recommendations.
My current system consists of a Linn Majik DSM feeding a Roksan Caspian M2 power amp into a pair of Neat Motive 2SE.
The room is smallish, approx 4m square and has solid floor with thick stone walls; as a result, the sound could be described as well damped although bass can appear overblown at times with certain material at higher volumes (not always an issue though).
We listen to a mix of music from pop/rock (Eagles, Fleetwood Mac, Steely Dan, Alison Kraus) through old school dance to classical.
Although, at times, I am very happy with the sound, at others, I feel as though there is more to be had! Budget is up to £2500.
Initial thoughts are to consider:
PMC twenty series
Neat Elite or Momentum
Proac
Not sure either whether to go for floor standers or stand mount. Have recently read reviews for KEF LS50 and think they should also go on the list. I know that this quest appears rather open ended at the moment but the timescale could easily be 12 months so the list can gradually be narrowed down. Any suggestions much appreciated
PMC twenty series
Proac
