Yet another question about the Naimuniti
As with many other people on this forum, I am considering buying a Naimuniti, as with any big purchase, I've asked around to get people opinion, one shop said that the issue with Naim in general is that Naim only works well with other Naim products; is this still the case? In the future, I would probably consider buying power amp, but I don't want to be limited to one manufacturer. Has anyone got any experience with this? Thanks.
I read the Naim forums quite a bit and whilst yes the majority of Naimees have all Naim kit, there are plenty of others that mix and match.
As for myself, I have not felt the need to add a power amp. My listening room is approx 4.5m x 3.5m so not large by any means and I don't try to play at room shaking volumes and the Uniti is absolutely more than capable of driving my EB1's with ease. In any case the whole point of buying my Uniti was to do away with lots of boxes and cables. I play a lot of vinyl so I have to tag on a phono amp, but thats all.
Thanks for your thoughts. I am pleased to see that you can mix and match with Naim.
My room is 4.5 x 6.5 and it will be driving a pair of montior audio RX6s. A shop (who doesn't stock Naim) suggested that the Naim might not be able to control these speakers, though the cynic in my says, there trying to sell me one of their own products, it has put an element of doubt in my mind. I did try this combo out at a shop but the room was very small.
Ideally you could do with a home trial to find out for sure.
David@Frank Harvey HI-Fi could give you a much better opinion than I can.
msaville:
Naim kit does work well with other manufacturers; see my signature. But you must have a listen, and be prepared for a bit of a cable faff (although I imagine that wouldn't be a problem with the Uniti).
jockey.wilson:msaville:
Yes, speaker cables are not a problem for the Uniti - the manual states that although Naim's NAC A5 should give best results, other speaker cables can be used safely. I use Chord Epic, which I find more detailed and refined than the NAC A5.
Many thanks for all your responses, i feel better armed now. If there is someone out there with Uniti and RX6 mix i would still like to hear from you. Cheers!
