YAMAHA RX-A3030+ BEST MATCHING SUBWOOFER ?
Matt786
7
Hi, I have just got Yamaha RX-A3030 Av reciver. Now i am looking to buy best matching floor standing speakers to go with it and a subwoofer , the maximum price for the floor standing spekers should not be more then 1200.00 pounds.
Just to clarify; are you looking for a 2.1 setup? Does the budget include the subwoofer as well? How big is your room? Can't help thinking that you've not left much budget for your speakers + subwoofer, and the RX-A3030 may not be able to perform to its full potential. Unless you have a separate budget for a subwoofer.....
Matt786
7
I Have attched to it Boose Acoustimass 10 ( 5.1) which i had them already . Now i would like to add up pair of floor standing speakers and a second subwoofer . 1200 is just for the speakers it can go up 1500 in case .Room is around 25/20 Ft i thing could be a little bigger.
