YAMAHA combo S-2000.... help please
Hello everyone,
I would like to know the opinion of those who live with the components of the series s-2000's yamaha ... what do you think of your performance?
what do you think of your CD player?
what do you think the amp?
what do you think of the combo?
has anyone heard them with magneplanar 1.7? will be a good team?
in your opinion, the combo s-2000 is superior or inferior in quality to the sound combo Primare 32 series?
I thank all of you who can help!
with best regards!
Hello lipe, Buy with confidence. Had my pair just over 12 months sound superb, build and finish 1st class, use mine with atc scm 11,s. regards
I have the AS-1000 (very similar to AS-2000) amplifier for several months now and i am very happy with it even after comparing it at my home with more expensive amplifiers and preamp/power amp combos. It drives my Dynaudio Focus 110 speakers without a problem and produces a tight and deep bass. Build quality is indeed first class.
If you leave the amp on all the time (like you have to do with Naim, Plinius and some others) the sound even improves quite a bit after a 1-2 days.
