Wireless Video Sender
D.J.KRIME
160
Can anyone recomend a Wireless video sender that actually works? I have tried 2 differant ones and on both the picture was appaling. The distance between is about 35m through 1 wall.
if you got wireless broadband forget it, they just dont work. i had an excellent philips one i used to use never had no bother with it, then as soon as i went wireless with my b/b had the same trouble as you. tried swapping the channels re-posistioning the transmitter and receiver all to no avail
Yes have wireless Broadband. So there are not any units on the market that are not affected by your wireless BB?
not that i've found. i tried two others as well as the philips both had same trouble. with the ones youve tried, if you switch your router off and any wireless kit your probably find they work great
edit- i think the problem is iirc, wireless b/b transmits a 2.4 ghz signal and so do the video senders. if you can find a video sender that transmits at a different frequency you may be ok
This is silly, how can they make units that are on the same frequency as BB? Surely every unit they actually sell gets returned?
