Wireless 5.1 speakers
Petruchio
27
Hello. First post for me!
I'm looking for a wireless 5.1 speaker kit. I have a Sony str-da5200es amp so will I need to buy a wireless adapter or do the speakers come with it?
My budget is £700-£1000.
Any help or pointers would be most appreciated!
Do you want a completely wireless system, or could you live with just the rear speakers being wireless?
If the latter, then you could use virtually any speaker system with the addition of KEF's wireless speaker adapter system, which will connect to the rear channel preouts of the receiver and feed the rear speakers.
It's not cheap, at about £400, but then it does include transmitter, receiver and two power amps.
Buying that would leave you about £600, so easily enough for a speaker system such as the KEF KHT2005.3, or if you fancy traditional speakers the Q Acoustics 1010i 5.1 system.
