Windows live mail
simonlewis
590
A quick question, when my e-mails are down loaded to WLM the new e-mails are at the top of the screen how do i change it so they are at the bottom of the screen so the new e-mails are underneath the old ones, i've just got windows 10 BTW, YaY. *dance4*
You should be able to click on the received icon and have the order reverse, or click 'descending' and it should change to 'ascending'. Or vice versa. But hurry up and do it before Microsoft ditches WLM completely!
simonlewis said:
Where is that just had a look and couldn't find it ?
Second column top right.
Are you sure you are using the WLM program, and not the Windows 10 Mail App, as all WLM program versions are similar. (The Win 10 Mail App is just a basic program with limited options)
Bill
simonlewis said:
I probably have the win 10 mail app it's what came up when i googled it.
Then as I suggested in another thread, a standalone mail program might be a good idea.
Can you give example/s please as i don't know of any other, ta.
