Will this Work? (Turntable, amp & Speakers)
DerekAJ said:
Thank You, I understand what You are saying and I am grateful... Please may I ask a basic question (which I think I have right) but being as I'm here, it can't cause no harm. The Rotel Ra01 (which I've seen from pics) has a speaker a bank and speaker b bank for bi wiring. Do I just use Speaker A bank? (as I'm not bi-wiring) Thank You.
Yes DerekAJ, if you avoid the bickering of others, you assume correctly regards wiring. You only need to connect cables to the set marked A. Your amp can connect a second pair of speakers but do not confuse this with bi-wiring
Actually this is only part of the story.
What Al says is fine as far as it goes but the 610 does have a switchable 'bi amp' facility, where both speaker A and speaker B are used at the same time into speakers with two sets of terminals (bi-wire).
In this mode each set of speaker terminals are fed by their own stereo amplifier in full bi-amp mode, this should be avoided at pretty much all costs.
Well try it out and play around where possible with speaker positioning, toe-in etc. 6 feet high is prob a bit too high can you have them lower? You can buy brackets that tilt them down. To be honest in that room you maybe better off with some decent headphones, does your amp have a headphone socket?
