will these wall mounts be ok?
markyboy156
203
hi i have 2 monitor audio rx1 speakers i need to wall mount them as front height speakers can you tell me will these wall mounts be ok to use http://www.superfi.co.uk/p-4021-apollo-wall-mount-speaker-brackets-pair.aspx if so would i need the front to back grip or the side to side grip version thanks could somebody reply asap please
Can't see no issue with using these. Though, Monitor Audio use a third party company called B Tech to manufacturer brackets for their speakers. It may be worth giving them a call. They'll probably be less bulky and 'heavy duty' looking as well.
