T
the record spot
Give it a try and see what you think, but I just run one set and connect some standard cable between the two sets of binding posts on the 752s.
Gareth82 said:ive just been offerd some mission 753 (originals). Are these speakers any good and what is the bass response like? my amp is rated at 100 watts per channel, would that be enough power to drive the missions? Thanks
Gareth82 said:Thank you everyone for the recconmendations on which amp to use, i will be looking further into all of these in more detail, i've never thought of using a tube amp before and the ability of being able to upgrade it does appeal to me. would any of the more recent amps like the Marantz PM6003 or Yamaha A-S500 be any good?
Gareth82 said:After being recconmended the Yaqin MC-10L Valve amp ive been doing abit of hunting around and found that they also make the SD 30-A Valve CD Player, SD-CD3 Tube Signal Upgrade Buffer (No idea what one of these is) and PH-5L Valve Headphone Amp. Has any one heard or own any of these and are they worth considering to partner with the mission 753.
