- Aug 10, 2019
- 2,556
- 4
- 0
Lots of work going on at the moment! Have finally found a screen and the folks have taken the news rather well. Which is a relief as the darned thing costs a fortune. Screen Research from the States. Acoustically transparent 96inch screen. Don't ask what it costs as it's too embarrassing. Ok, here's the dilemma, I'm hoping that Andrew or Claire will have a view on this, or anyone else with projector knowledge. I was thinking of buying an Infocus IN82. But all the dealers I've spoken to say buy an Optoma Theme-Scene HD81. They both cost £3000. So there's nothing in it on price. I don't need any vertical lens shift and they both fit the screen in terms of throw ratio. But then one dealer has said that with a screen that large we should really go for the HD81 LV which stands for Large Venue. It's basically a shed load brighter and should suit an 8ft screen much better. Costs a grand more. Please can I have you views. Is it a good idea to get the LV. Is it really going to be noticeable? Is the Infocus IN82 that won this years award better than the standard Optoma Theme-Scene HD81? This is a critical time in the building work. The screen is agreed and it's the real critical element at present, but the projector will be needed very shortly, so all the advise you can give will be gratefully appreciated! All the best! Will
