Which? Pioneer VSX-LX60 or Denon AVR-2308
Hi
Can't decide which one to go for.
The amp will be situated under the stairs and controlled using a Harmony 1000.
I am leaning towards the Pioneer as it is a better spec but my only problem is can I tell which output it is on if I don't use the original controller?
pioneer might sound a little abrasive...if it look good, show it! I love to see the amp below the tv...
I do like the looks of them but the my setup is the nice and clean look so all you see is the TV on the wall and nothing else.
Does anyone know what they are like to live with?
The Pioneer has more connectivity over the Denon which is a bonus.
there's a review here of the vsx-lx70.in sound quality it shoudn't differ much from the 60.Yes connectivity is very important, but i guess in the end, sound is more.guess i would go for the onkyo875, both in sound and specs...not so sure about built quality nonetheless..
