which new speakers
steakers
102
i have £350.00 for a set of new front bookshelf speakers im currently using missions 771i as my fronts and im looking for a new replcement pair , 60% home cinema and 40% audio i use them for , they run of a STR DH810 amp .any tips or recommendations welcome
thanks .
sta99y
137
As you have a mission centre then really you need to stay with Missions so you get the tonal Match across the front three. Unless you upgrade the front three as this could be a better option. I don't know you're speakers but I'm sure others here do and can recommend something.
well if your sticking with missions then the mission mx2 or mx1's seem to have very good reviews and are well below your £350 budget and are bookshelf speakers.
however if you do have the room you can get a pair of mission Mx3's for the £350 you have, they are floorstanders and have a what hi-fi 5 star review
